[OpenLayers-Trac] [OpenLayers] #2837: Panel control: Remove a "redraw" redundant.
OpenLayers trac-20090302 at openlayers.org
Mon Sep 13 18:15:56 EDT 2010
 Reporter:  jorix          |       Owner:
     Type:  bug            |      Status:  new
 Priority:  trivial        |   Milestone:  2.11 Release
Component:  Control.Panel  |     Version:  2.10
 Keywords:                 |       State:
 The patch removes the "redraw" and change the test to show that only
 happens a "redraw"
 The "redraw" occurs by control.events.on in "activate" and "deactivate",
 the explicit "redraw" is unnecessarily.
 Note: In #2752 also proposed to prevent "redraw" but required to add code,
 not remove it, as here.
 Test ok in: FF36, IE8, Chrome6 & Safari5.
Ticket URL: <http://trac.openlayers.org/ticket/2837>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
