[OpenLayers-Trac] Re: [OpenLayers] #2834: Panel control: Allow to
use "autoActivate" in the panel's controls.
trac-20090302 at openlayers.org
Thu Sep 23 12:31:17 EDT 2010
#2834: Panel control: Allow to use "autoActivate" in the panel's controls.
Reporter: jorix | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Control.Panel | Version: 2.10
Keywords: | State: Needs More Work
Comment(by jorix):
Replying to [comment:8 ahocevar]:
> Your ups, ups^2 and ups^4 comments don't make sense to me. Also -
correct me if I am wrong - I was under the impression that a control won't
be activated before it is added to the map.
I explained wrong (I have very clear that control must be activated after
add it to the map) I understood that you in comment:6 (may be I
misunderstood) proposed change
control.events.on({
"activate": this.redraw,
"deactivate": this.redraw,
scope: this
to
control.events.on({
"activate": this.onActivateControl,
"deactivate": this.onDectivateControl,
scope: control // "this" to "control"
and "this.onActivateControl" has the logic to ensure that only a
"TYPE_TOOL" is active (now this is in "activateControl"). The code in the
second part of my comment:7 would be the end (simplified) of
"this.onActivateControl" but conditioned by #1414.[[BR]]
If you do not think otherwise I do not need to go into more details about
this.
Returning to the first part of my reply to your comment:5. I think the
complexity of this patch is required, for example when a panel with
"autoActivate" to false is added to the map.[[BR]]
What is your opinion on this?
Ticket URL: <http://trac.openlayers.org/ticket/2834#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
