[OpenLayers-Trac] Re: [OpenLayers] #2819: Format.XML could add
xmlns attributes by default
trac-20090302 at openlayers.org
Fri Apr 1 09:13:01 EDT 2011
#2819: Format.XML could add xmlns attributes by default
Reporter: bartvde | Owner: erilem
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Format.XML | Version: 2.10 RC1
Keywords: | State: Needs More Work
Changes (by erilem):
* state: Review => Needs More Work
Comment:
My review comments:
* the patch doesn't apply to the current trunk
* calling {{{write}}} with something else than an {{{ELEMENT_NODE}}} will
cause an error when attempting to access the {{{attributes}}} or
{{{setAttribute}}} property
* in my opinion the patch deserves new tests in tests/Format/XML.html. In
particular I'd like to see tests providing evidences that the "avoid
duplicates" code is necessary
I'm not an XML expert, so I'll defer the final word to our OGC/XML gurus.
Ticket URL: <http://trac.openlayers.org/ticket/2819#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
