[OpenLayers-Trac] [OpenLayers] #3239: The use of "eventsDiv" cause
problems with "mouseout"
trac-20090302 at openlayers.org
Sun Apr 3 05:42:59 EDT 2011
#3239: The use of "eventsDiv" cause problems with "mouseout"
Reporter: jorix | Owner: tschaub
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Handler | Version: SVN
Keywords: | State:
After #3091 the controls are out of "eventsDiv". And they behave as if
they were off the map, not affected by events on the map.
To avoid problems with the handlers "Drag", "Point" and "Hover" must
identify the "mouseout" events when the mouse enters into "div" of a
control.
Problems:
1 Drag the map without press the mouse (using example.html)
* Initiate a drag
* Release the mouse over a control
* Move, oops! the drag is still active
(With panel.html can see the same effect produced by
Control.MouseDefaults)
2 The point not follow the cursor (using editingtoolbar.html)
* Select draw (point, line or polygon)
* Move, ok! the point follows the cursor.
* Initiate a drag
* Move, oops! the point does not follow the cursor.
The effect to "Hover" are more subtle. With "GetFeature-wfs.html" can
activate a state when the cursor is outside its area, over a control (It
does not trigger the "move").
Proposal: use "eventsDiv" instead of "viewPortDiv" on "mouseout"
NOTE: This patch also fixes #3005
Ticket URL: <http://trac.openlayers.org/ticket/3239>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
