[OpenLayers-Trac] Re: [OpenLayers] #3240: test_Handler_Box_draw
fails
trac-20090302 at openlayers.org
Mon Apr 4 16:30:24 EDT 2011
#3240: test_Handler_Box_draw fails
Reporter: erilem | Owner:
Type: task | Status: closed
Priority: major | Milestone: 2.11 Release
Component: tests | Version: 2.10
Resolution: fixed | Keywords:
State: |
Comment(by jorix):
Test ok: FF3.6.16, IE8, IE7 and IE6:
test_Handler_Box_draw ok 2
ok box result correct
ok box removed after endBox
Test ok: Chrome-10 and Safari-5:
test_Handler_Box_draw ok 12
ok x position of box correct
ok y position of box correct
ok x position of box still correct
ok y position of box still correct
ok x dimension of box correct
ok y dimension of box correct
ok new x position of box correct
ok new y position of box correct
ok x dimension of box still correct
ok y dimension of box still correct
Ticket URL: <http://trac.openlayers.org/ticket/3240#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
