[OpenLayers-Trac] Re: [OpenLayers] #3242:
wfs-protocol-transactions.html: When draw
the insertion point jump and follows the mouse away
trac-20090302 at openlayers.org
Mon Apr 4 18:43:01 EDT 2011
#3242: wfs-protocol-transactions.html: When draw the insertion point jump and
Reporter: jorix | Owner:
Type: bug | Status: closed
Priority: critical | Milestone: 2.11 Release
Component: general | Version: SVN
Resolution: wontfix | Keywords:
State: |
Changes (by tschaub):
* status: new => closed
* resolution: => wontfix
Comment:
Ok, wild goose chase.
The issue is that in r10554, the default for Google, Yahoo, and Virtual
Earth layers was changed to {{{wrapDateLine: true}}}. Since in
OpenLayers, the "date line" is considered the {{{maxExtent}}} of a
'''layer''' (not the map), if you set the max extent of your base layer to
something other than the world, {{{wrapDateLine}}} has no meaning.
We should have put something in the 2.10 release notes about this. We
could put something in the 2.11 release notes if that sounds good.
A solution for the wfs-protocol-transactions.html is demonstrated in
r11872. A (perhaps simpler) one is to set {{{wrapDateLine: false}}} in
the Google layer constructor for that example. Both work.
Please reopen this ticket if you think there is something else we should
do about it.
Ticket URL: <http://trac.openlayers.org/ticket/3242#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
