[OpenLayers-Trac] Re: [OpenLayers] #3237: Issue with filter params
in Protocol/HTTP.js
trac-20090302 at openlayers.org
Tue Apr 5 02:09:12 EDT 2011
#3237: Issue with filter params in Protocol/HTTP.js
Reporter: etdube | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Protocol.HTTP | Version: SVN
Keywords: filter http protocol | State: Commit
Changes (by erilem):
* state: Review => Commit
Comment:
Replying to [comment:7 etdube]:
> This also means the second call to read() in the test has a side effect
of assigning this.options.param to the options object passed to read()
(i.e. opt2), therefore opt2.params will contain leftover stuff (i.e. the
{{{foo__eq}}} filter param) from the first call that shouldn't be there.
The API docs explicitly state that the options object passed to read is
modified by read and should not be reused. So I'd suggest that we only
test that read doesn't write to {{{protocol.options.params}}}. See
[attachment:http_filter_params_fix_with_test.2.patch]. I'll commit that if
you agree.
Ticket URL: <http://trac.openlayers.org/ticket/3237#comment:8>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
