[OpenLayers-Trac] Re: [OpenLayers] #3249: style.label.split is not
a function
trac-20090302 at openlayers.org
Wed Apr 6 15:09:31 EDT 2011
#3249: style.label.split is not a function
Reporter: stricsc | Owner: crschmidt
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Layer.Vector | Version: 2.10
Keywords: | State:
Comment(by stricsc):
Attached is a file based on one of your development examples. The issue
seems to be with the object label ('name'). If I use a numeric for the
label, I get the
style.label.split is not a function. I also tried i.toString() and
String(i) without any success. Also tried i.toString() + " " which did
not work. Using any alpha character seems to fix the issue.
Ticket URL: <http://trac.openlayers.org/ticket/3249#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
