[OpenLayers-Trac] Re: [OpenLayers] #3249: style.label.split is not a function
OpenLayers trac-20090302 at openlayers.org
Wed Apr 6 18:24:29 EDT 2011
 Reporter:  stricsc       |       Owner:  tschaub
     Type:  bug           |      Status:  assigned
 Priority:  major         |   Milestone:  2.11 Release
Component:  Layer.Vector  |     Version:  2.10
 Keywords:                |       State:  Review
Changes (by tschaub):
  * owner:  crschmidt => tschaub
  * status:  new => assigned
Comment:
 The alt patch casts to string in {{{style.createSymbolizer}}}.  Here's the
 difference:
 With the first patch (cast in renderers) we are very safe, never calling
 split unless we know we have a string.  This means people can use the
 (API) {{{layer.drawFeature}}} method and pass a "style" like this
 {{{{label: 123}}}} and things still work.
 However, if we tell people who are using the {{{drawFeature}}} method
 directly that the label member of a symbolizer must have a string value,
 then we don't need to be so conservative.  We only need to cast to a
 string when we create a symbolizer given a feature.  This covers cases
 where a label value might come from a numeric attribute.
 I'm fine with either, but I like the less conservative patch (alt patch
 with cast in Style.js) better because we need to get people to stop
 calling {{{layer.drawFeature}}} directly anyway.
Ticket URL: <http://trac.openlayers.org/ticket/3249#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
