[OpenLayers-Trac] [OpenLayers] #3251:
OpenLayers.Layer.Vector.addFeatures() causes Chrome to reload page
trac-20090302 at openlayers.org
Thu Apr 7 10:24:54 EDT 2011
#3251: OpenLayers.Layer.Vector.addFeatures() causes Chrome to reload page
Reporter: kkelley4va | Owner: crschmidt
Type: feature | Status: new
Priority: major | Milestone: 2.10 Release
Component: Layer.Vector | Version: 2.10
Keywords: Chrome addFeatures | State:
'''Background'''
We are using OpenLayers on top of the Google map api. This is only an
issue on Chrome (10.0.648.204) and not IE or FF. We also have dojo 1.5
included in our application to generate menus and other controls.
Adding a marker on top of a google map works fine. However, once the page
completes loading, it is requested a second time. I noticed because I had
some breakpoints set on code used to render some dynamic fields. Before
the map/marker is rendered the breakpoint is hit. After the page
completes loading it is hit again.
If I comment out "map.vectorLayer.addFeatures([feature]);" from the code
below, the page doesn't get requested twice, but of course the marker
isn't created.
function createMarker(input)
if(input.longitude==undefined || input.latitude==undefined &&
input.address!=undefined)
createAddressMarker(input);
return null;
if(input.longitude==undefined || input.latitude==undefined)
return null;
var iconURL = null;
var iconW = (input.options.iconW!=undefined) ? input.options.iconW
: 20;
var iconH = (input.options.iconH!=undefined) ? input.options.iconH
: 20;
if(input.options.icon!=undefined)
iconURL = input.options.icon;
else
iconURL = DEFAULT_MAP_ICON;
input.options.icon = iconURL; //re-assigned
input.options.iconW = iconW;
input.options.iconH = iconH;
var map = TheMaps[input.mapid];
map.vectorLayer = new OpenLayers.Layer.Vector("Markers",
{displayInLayerSwitcher: false, reproject: true});
map.vectorLayer.events.includeXY = true;
map.vectorLayer.display(true);
map.vectorLayer.projection = map.displayProjection;
map.vectorLayer.preFeatureInsert = function(feature)
//we always with with EPSG:4326, need to convert it to map
projection
feature.geometry.transform(map.displayProjection,
map.projection);
map.addLayer(map.vectorLayer);
map.selectControl = new
OpenLayers.Control.SelectFeature(map.vectorLayer, {clickout: true});
map.vectorLayer.events.on({"featureselected": onFeatureSelect,
"featureunselected": onFeatureUnselect});
map.addControl(map.selectControl);
map.selectControl.activate();
var feature = new OpenLayers.Feature.Vector(new
OpenLayers.Geometry.Point(input.longitude, input.latitude), null,
{externalGraphic: iconURL, graphicHeight: iconH, graphicWidth:
iconW});
feature.input = input;
feature.id = input.id;
if(input.checked==true)
feature.style.display = 'block';
else
feature.style.display = 'none';
map.vectorLayer.redraw();
return [feature];
Ticket URL: <http://trac.openlayers.org/ticket/3251>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
