[OpenLayers-Trac] [OpenLayers] #3262: OpenLayers Event objects in
Firefox have unstable 'getPreventDefault' methods.
trac-20090302 at openlayers.org
Mon Apr 18 12:13:57 EDT 2011
#3262: OpenLayers Event objects in Firefox have unstable 'getPreventDefault'
methods.
Reporter: mgleahy | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
On line 37 of the attached html file, the getPreventDefault method is
present and called (in Firefox)...at that point, you will get the
following error reported:
uncaught exception: [Exception... "Illegal operation on WrappedNative
prototype object" nsresult: "0x8057000c
(NS_ERROR_XPC_BAD_OP_ON_WN_PROTO)" location: "JS frame ::
http://localhost/openlayers/examples/clickEventsDebug.html :: <TOP_LEVEL>
:: line 36" data: no]
Line 0
It seems to me that either the getPreventDefault method should not be
present as a property of the OpenLayers event object, or if it is, it
should not crash the JavaScript code when it is called. I encountered
this because I had been using the jQuery $.event.fix() method in my
application, and upon the upgrade to 1.5.2 of jQuery, the $.event.fix()
method started checking for this method.
The attached file also illustrates a workaround I was able to use, where I
overrode the getPreventDefault function with a new empty function (though
I think deleting the property or setting it false would work as well).
Ticket URL: <http://trac.openlayers.org/ticket/3262>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
