[OpenLayers-Trac] Re: [OpenLayers] #3272: Handler.Path: It is not possible to draw accurately
OpenLayers trac-20090302 at openlayers.org
Wed Apr 27 00:38:59 EDT 2011
 Reporter:  jorix         |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  critical      |   Milestone:  2.11 Release
Component:  Handler.Path  |     Version:  SVN
 Keywords:                |       State:  Needs More Work
Changes (by erilem):
  * state:  Awaiting User Feedback => Needs More Work
Comment:
 With the current code we have a tolerance not to draw a second point when
 a second touch occurs at the same location as the first point. My patch
 removes this code, which is a problem I think. Okay, Needs More Work.
 (This issue isn't related to the one reported by jorix.)
 jorix, in the mean time it'd be great if you could investigate the
 "finalize geometry" issue in your Android device.
Ticket URL: <http://trac.openlayers.org/ticket/3272#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
