[OpenLayers-Trac] Re: [OpenLayers] #3276: Missing dependencies for Map and DragPan
OpenLayers trac-20090302 at openlayers.org
Wed Apr 27 08:48:40 EDT 2011
  Reporter:  jpulles           |       Owner:
      Type:  feature           |      Status:  reopened
  Priority:  minor             |   Milestone:  2.12 Release
 Component:  general           |     Version:  SVN
Resolution:                    |    Keywords:
     State:  Needs Discussion  |
Changes (by jpulles):
  * status:  closed => reopened
  * state:  => Needs Discussion
  * resolution:  wontfix =>
Comment:
 Sorry to reopen this issue as 'needs discussion', but I would like to
 argue that the requires statements should reflect what is in code.
 Alternatively, to the design decision can be noted in the file header.
 For DragPan the defaults are that Kinetic is not required, so this is ok.
 For Map.js however, the default code requires a Navigation control a.o. If
 the code would check for availability of these classes, the lack of
 @requires would be correct.
Ticket URL: <http://trac.openlayers.org/ticket/3276#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
