[OpenLayers-Trac] [OpenLayers] #3447: Bleeding of variables
trac-20090302 at openlayers.org
Tue Aug 2 12:51:19 EDT 2011
Reporter: jonasenander | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: BaseTypes.Class | Version: 2.10
Keywords: | State:
Don't know if it is intentional but there seems to be a kind of obscure
"feature"/bug when creating a "class" with OpenLayers.Class();
When creating a new class with a init function and a variable like so:
myObj.newClass = OpenLayers.Class({
clsArr: [],
clsObj: {},
clsStr: null,
initialize: function(){...},
and then creating two instances of said class:
myInst = new myObj.newClass();
myInst2 = new myObj.newClass():
and then adding data to the array in those instances:
myInst.clsArr[0] = "foo";
myInst2.clsArr[1] = "bar";
and then inspecting said array from one of the instances:
myInst.clsArr;
It will print:
["foo", "bar"];
So... In this case the arrays bleed.
Testing the other types of variables are solid tho.
fooObj = {};
fooObj.bar = "baz";
myInst.clsObj = fooObj;
myInst2.clsObj;
>> Object {}
myInst.clsStr = "abc";
myInst2.clsStr;
>> null
It is a case of esoteric execution behavior of the prototype paradigm I
suspect.
If the array-var is instead declared inside the initialize-function:
this.clsArr = [];
then it wont bleed. Im writing a revamped version of the OpenLayers.Class
function atm, but it isnt finished yet. But I dont know if you guys are
interested in that piece of code.
Feature or bug? :)
Ticket URL: <http://trac.openlayers.org/ticket/3447>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
