[OpenLayers-Trac] Re: [OpenLayers] #3441: Default opacity of layer
trac-20090302 at openlayers.org
Mon Aug 8 02:21:32 EDT 2011
Reporter: mosesonline | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Layer | Version: SVN
Keywords: layer | State: Needs More Work
Comment(by mosesonline):
All the layer tests are running well. Maybe the creators of the failing
classes/tests could help to solve why the classes/tests fail with visible
layers? WMC, Format/OWSContext/v0_3_1.html and Marker/Box tests fail, did
I missed some?[[BR]]
The first fails because the sanitize-method in the test changes the
version from 1.1.1 to 1.10000.1 and other floating point numbers or text
which looks like floating point to an unexpected format.[[BR]]
But these tests only fail when the tests are running with all tests as
batch when running only one test as a single test.
Ticket URL: <http://trac.openlayers.org/ticket/3441#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
