[OpenLayers-Trac] Re: [OpenLayers] #3441: Default opacity of layer
trac-20090302 at openlayers.org
Tue Aug 9 02:44:05 EDT 2011
Reporter: mosesonline | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Layer | Version: SVN
Keywords: layer | State: Needs More Work
Comment(by mosesonline):
But it seems that the formats do bother about the opacity, they work with
opacity null but not with 1. In a case where 1 is a documented value for
the property and null the undocumented default value. My app handles the
null value, because it has to, but why the format don't handle legal
values for this option? I would change it if I could, but I'm not so into
these classes. Maybe someone who wrote the classes could give a hint to
fix it. I would try to fix the errors in the classes or should the null
value stay?[[BR]]
Why I think it should be fixed:[[BR]]
The null value is sometimes "we don't bother", sometimes "oh, I forgot to
set", sometimes "Make it visible" and sometimes "Don't show it", it is
ambiguous. Ambiguous values lead to confusion and this leads to exceptions
or errors.[[BR]]
A layer is a visual component so it is always visible or not, and if it's
visible it has an opacity(that's why the Layer-class has this attribute
and not a subclass), if a client (class) doesn't bother it should not use
this value.[[BR]]
I cannot imagine a use case where the opacity of a layer must not be set,
at least to a default value 1. I can imagine several cases where it is not
used, but than I don't use it.[[BR]]
The last thing is that it leads to more code, where the user has to deal
an ambiguous value every time he wants to compute something with the
opacity.
Ticket URL: <http://trac.openlayers.org/ticket/3441#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
