[OpenLayers-Trac]
Re: [OpenLayers] #3431: set opacity on layer divs,
not on tiles and markers
trac-20090302 at openlayers.org
Tue Aug 9 15:09:11 EDT 2011
#3431: set opacity on layer divs, not on tiles and markers
Reporter: ahocevar | Owner: euzuro
Type: feature | Status: reopened
Priority: minor | Milestone: 2.11 Release
Component: Layer | Version: SVN
Resolution: | Keywords:
State: Review |
Comment(by erilem):
Replying to [comment:14 ahocevar]:
> Maybe an explanation about [attachment:opacity.patch] is in order: in
IE8, the filter is not applied to positioned child elements (like in our
case, where {{{style.position}}} is set to {{{absolute}}}). And in
addition, the filter needs to be applied ''after'' an image is loaded. So
we use a loadend listener and just set the filter again, to make sure that
it gets applied. In css, setting a width and height in pixels for the
layer div is also necessary, because otherwise the children won't render
at all. The whole workaround is only necessary for IE8.
Thanks Andreas for researching the issue, and providing an explanation for
it. I'm in favor of reverting r12185, to avoid introducing some
IE8-specific hackish code.
Ticket URL: <http://trac.openlayers.org/ticket/3431#comment:15>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
