[OpenLayers-Trac] Re: [OpenLayers] #3452: Panning doesn't redraw map vectors (linestrings) in Firefox
OpenLayers trac-20090302 at openlayers.org
Wed Aug 10 06:46:40 EDT 2011
 Reporter:  imanfafa      |       Owner:  crschmidt
     Type:  bug           |      Status:  new
 Priority:  critical      |   Milestone:  2.12 Release
Component:  Layer.Vector  |     Version:  2.10
 Keywords:                |       State:  Needs Discussion
Comment(by imanfafa):
 Replying to [comment:4 erilem]:
 > A full example would help. For example, in the code snippet you provided
 I don't know what {{{result}}} and {{{GetWGSPoint}}} are.
 I have found the solution and it was Firefox rendering problem, which I
 have assigned the vector renderer to "SVG2" and the problem has partly
 been solved. but not completely. because when I zoom-in the map to scales
 larger than 100m, all vectors are being hidden and when I zoom-out the map
 the vectors are being shown.
 The problem is a rendering bug and I'm searching thru the solution yet.
 This is the change:
 lineLayer = new OpenLayers.Layer.Vector("Line Layer", {renderers: ["SVG2",
 "VML", "Canvas"]});
Ticket URL: <http://trac.openlayers.org/ticket/3452#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
