[OpenLayers-Trac] [OpenLayers] #3472: OpenLayers.Control.Split does
not synchronize with other datastore
trac-20090302 at openlayers.org
Mon Aug 22 08:22:50 EDT 2011
#3472: OpenLayers.Control.Split does not synchronize with other datastore
Reporter: ckreuzbe | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
I wrote a little script for editing WFS-Data - basically I just used the
workshop from opengeo:
http://workshops.opengeo.org/geoext/wfs/editing.html
So yes, I am using GeoExt, and this is how the datastore looks like:
var layer = new OpenLayers.Layer.Vector("vector", {
strategies: [new OpenLayers.Strategy.Fixed(),
saveStrategy],
protocol: new OpenLayers.Protocol.WFS({
url: wfsUrl,
featureType: "someLayer",
featureNS: "http://somenamespace",
srsName: "EPSG:900913",
version: "1.1.0",
geometryName: "geom"
var store = new GeoExt.data.FeatureStore({
fields: [
{name: "type", type: "int", defaultValue:
0},
{name: "cost", type: "double",
defaultValue: 0.00},
{name: "text", type: "string",
defaultValue: ' '},
{name: "hierarchy", type: "int",
defaultValue: 0}
layer: layer,
addFeatureFilter: function(feature) {
return feature.state !==
OpenLayers.State.DELETE;
Now, this is working just fine with the split-control:
// configure split agent
split = new OpenLayers.Control.Split({
layer: layer,
source: layer,
tolerance: 0.0001,
deferDelete: true,
eventListeners: {
aftersplit: function(event) {
flashFeatures(layer,event.features);
// we should refresh the grid
map.addControl(split);
split.activate();
But: I am also using an Ext.grid.EditorGridPanel (from extjs 3.4), which
basically uses the store I just created as the input data.
[[BR]]
Now, with "deferDelete: true" I can make sure, that features that are
deleted/splitted will be updated/deleted on the WFS properly, but my
EditorGridPanel does not get any updates.
[[BR]]
And here is why:[[BR]]
openlayers/lib/OpenLayers/Control/Split.js[[BR]]
or[[BR]]
tags/openlayers/release-2.10/lib/OpenLayers/Control/Split.js[[BR]]
Line 445:
this.layer.destroyFeatures(destroys, {silent:
true});
for(var i=0, len=additions.length; i<len; ++i)
additions[i].state =
OpenLayers.State.INSERT;
} else {
this.layer.destroyFeatures(removals, {silent:
true});
this.layer.addFeatures(additions, {silent: true});
The parameter silent: true is set when using destroyFeatures and
addFeatures. This parameter forces the above methods to NOT fire any
events, which causes external views, like a DataGrid, to be out of sync,
which causes errors.
I suggest adding another parameter to the Split Control, e.g.
keepSynchronized (default: false - don't change the default behaviour,
right?), and change the code to:
* APIProperty: keepSynchronized
* {Boolean} Instead of adding and removing features silently (silent:
true),
* add or remove them non silently (silent: false)
keepSynchronized: false,
!this.keepSynchronized});
} else {
I tested this and it worked for my example. Would be nice if it could get
included in the 2.11 release too!
I hope this will also help someone else having similar problems.
Ticket URL: <http://trac.openlayers.org/ticket/3472>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
