[OpenLayers-Trac] Re: [OpenLayers] #3472: OpenLayers.Control.Split
does not synchronize with other datastore
trac-20090302 at openlayers.org
Mon Aug 29 04:22:38 EDT 2011
#3472: OpenLayers.Control.Split does not synchronize with other datastore
Reporter: ckreuzbe | Owner: tschaub
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Control.Split | Version: SVN
Keywords: Split WFS Vector Store Synchronize Silent | State: Needs Discussion
Comment(by ckreuzbe):
It did not work with former versions either, it looks like even the first
revision of this file had "silent: true" set. However, it is breaking
compability, because listeners are not getting informed about any updates,
while documentation suggests that you can listen to remove and add events
on the VectorLayer:
http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/Vector-
js.html#OpenLayers.Layer.Vector.EVENT_TYPES
While with deferDelete the control will set the status of
updated/deleted/added features (which means the WFS will get informed
about the updates/deletes), listeners will not get informed about any
updates.
Long story short: It does not make sense to always surpress event
triggering, hence the new property.
As the change itself is really not that big, I would suggest getting it
into 2.11, but it's not me to decide.
Ticket URL: <http://trac.openlayers.org/ticket/3472#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
