[OpenLayers-Trac] Re: [OpenLayers] #3475: Google base layer not
showing when switching base layers
trac-20090302 at openlayers.org
Mon Aug 29 16:41:05 EDT 2011
#3475: Google base layer not showing when switching base layers
Reporter: guendhoer | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Layer.Google.v3 | Version: 2.11 RC3
Keywords: | State: Needs More Work
Changes (by guendhoer):
* state: Awaiting User Feedback => Needs More Work
Comment:
Hello,
thank you for your reply,
I found the real issue now, it has to do with the map.updateSize()
function which I call on window resizes. I need to call it because
otherwise the vectors won't be at the right positions after resize.
However, I have prepared an example for you, you can test it here:
http://guendhoer.com:9000/oltest.html
1) Load the page with maximized window, open Layer Switcher
2) Un-Maximize the window or resize it, then choose another Google Layer
-> nothing will happen
Tested with IE, Firefox, Safari, Chrome. If it works first time please try
again, 95% of the time it won't work.
Thank you for your work!
Best regards,
Stefan Gündhör
Ticket URL: <http://trac.openlayers.org/ticket/3475#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
