[OpenLayers-Trac] Re: [OpenLayers] #3475: Google base layer not
showing when switching base layers
trac-20090302 at openlayers.org
Tue Aug 30 07:24:10 EDT 2011
#3475: Google base layer not showing when switching base layers
Reporter: guendhoer | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: Layer.Google.v3 | Version: 2.11 RC3
Keywords: | State: Needs More Work
Comment(by guendhoer):
Google copyright is now showing up again after adding
Control.Attribution() - everythink is working fine for me now (using
GoogleNG), thank you very much for your help.
Replying to [comment:9 guendhoer]:
> Ahhhh you are right!! I already tried to use GoogleNG but I guess I
instantiatet it the wrong way. Now it is working for me! Surprisingly I
don't see any Google Logo anymore - but that doesn't really bother me ;-)
> So it was not a bug? Are users supposed to use GoogleNG in future
instead of normal Google Layer?
> Replying to [comment:8 fredj]:
> > Replying to [comment:2 bartvde]:
> > > Hi, are you able to check if using !OpenLayers.Layer.GoogleNG
instead would fix your issue?
> > You're right: using GoogleNG fixes the issue.
> > @guendhoer: you can change your tree layers creation from:
> > new OpenLayers.Layer.Google(
> > "Google Physical",
> > {type: google.maps.MapTypeId.TERRAIN}
> > to:
> > new OpenLayers.Layer.GoogleNG({
> > name: "Google Physical",
Ticket URL: <http://trac.openlayers.org/ticket/3475#comment:10>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
