[OpenLayers-Trac] Re: [OpenLayers] #3475: Google base layer not showing when switching base layers
OpenLayers trac-20090302 at openlayers.org
Wed Aug 31 11:39:31 EDT 2011
  Reporter:  guendhoer        |       Owner:
      Type:  bug              |      Status:  reopened
  Priority:  major            |   Milestone:  2.11 Release
 Component:  Layer.Google.v3  |     Version:  2.11 RC3
Resolution:                   |    Keywords:
     State:  Needs More Work  |
Comment(by bartvde):
 I just did a diff between 2.10 and 2.11 and am suspicious about the
 following change: resized was previously stored on the layer object, now
 on the shared cache:
 @@ -181,16 +162,15 @@
          if (this.visibility) {
              google.maps.event.trigger(this.mapObject, "resize");
          } else {
 -            var cache = OpenLayers.Layer.Google.cache[this.map.id];
 -            if (!cache.resized) {
 +            if (!this._resized) {
                  var layer = this;
                  google.maps.event.addListenerOnce(this.mapObject,
 "tilesloaded", function() {
 +                    delete layer._resized;
                      google.maps.event.trigger(layer.mapObject, "resize");
                      layer.moveTo(layer.map.getCenter(),
 layer.map.getZoom());
 -                    delete cache.resized;
 -            cache.resized = true;
 +            this._resized = true;
Ticket URL: <http://trac.openlayers.org/ticket/3475#comment:21>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
