[OpenLayers-Trac] [OpenLayers] #3483: Integration with javascript
module loaders (AMD)
trac-20090302 at openlayers.org
Wed Aug 31 18:51:08 EDT 2011
#3483: Integration with javascript module loaders (AMD)
Reporter: aprilmay | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.12 Release
Component: general | Version: 2.11 RC3
Keywords: | State:
_getScriptLocation works only if !OpenLayers is defined in a <script> tag,
making the library incompatible with AMD's require(). In a practical case:
we use Dojo 1.7 and have to load maps on demand.
Tweaking _getScriptLocation is easy and everything works fine (hard code
as quick and dirty workaround).
It could be resolved elegantly by using an optional predefined
configuration variable (olConfig, like Dojo's djConfig).
Another related point, specific to Dojo: we had to register !OpenLayers
explicitly in the global scope because of a security feature (with this
solution: add "window.!OpenLayers=!OpenLayers" at the end of the main
script).
Finally, i feel that a library like !OpenLayers would greatly benefit from
using extensively AMD specs: automatically loading required modules only,
thus reducing the network load and improving the speed, permitting the use
of flexible build systems, improving the integration with javascript
frameworks and adding server side capabilities, among probably other
advantages.
Ticket URL: <http://trac.openlayers.org/ticket/3483>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
