[OpenLayers-Trac] [OpenLayers] #3592: Cannot draw hole on
multipolygon
trac-20090302 at openlayers.org
Fri Dec 2 09:37:32 EST 2011
#3592: Cannot draw hole on multipolygon
Reporter: fradal | Owner:
Type: bug | Status: new
Priority: minor | Milestone:
Component: general | Version:
Keywords: | State:
Something strange happens using the holeModifier key in a multipolygon
geometry.
To reproduce this bug:
- open donut.js in the 2.11 examples folder
- add multi: true option to handlerOptions:
- replace this line (line 20)
{handlerOptions: {holeModifier: "altKey"}}
- with this
{handlerOptions: {holeModifier: "altKey", multi: true}}
- draw a polygon and close it (double click)
- keep the alt key pressed and try to draw another polygon within the
first drawn
Nothing is drawn, and if you try to move the mouse out of the first
polygon, the pointer remains inside the drawn polygon.
Trying to understand the problem, I've noticed that addComponent return
false because of this:
OpenLayers.Util.indexOf(this.componentTypes, component.CLASS_NAME) > -1)
(Geometry/Collection.js : 160)
probably because
componentTypes: ["OpenLayers.Geometry.Polygon"],
(Geometry/MultiPolygon.js)
does not contain OpenLayers.Geometry.LinearRing
I've tried to add LinearRing to componentTypes.
The hole polygon is drawn, but it is not an hole, but another polygon.
Ticket URL: <http://trac.openlayers.org/ticket/3592>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
