[OpenLayers-Trac] Re: [OpenLayers] #3592: Cannot draw hole on multipolygon
OpenLayers trac-20090302 at openlayers.org
Mon Dec 5 08:19:20 EST 2011
 Reporter:  fradal           |       Owner:  tschaub
     Type:  bug              |      Status:  new
 Priority:  minor            |   Milestone:
Component:  Handler.Polygon  |     Version:  2.11
 Keywords:                   |       State:
Comment(by fradal):
 I've tried to fix the polygon selection problem, I hope this helps.
 Patch is attached. I've tested it with more than one polygon and it works
 as I expected.
 I'm sorry if the patch does not match OpenLayers coding guidelines.
 Feel free to modify whatever you want.
Ticket URL: <http://trac.openlayers.org/ticket/3592#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
