[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Thu Feb 3 03:12:34 EST 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Needs More Work
Changes (by erilem):
  * state:  Review => Needs More Work
Comment:
 I'd like not to introduce business logic in the ModifyFeature control. For
 example, with [attachment:patch-modifyfeature-3016-r11065-A0.diff],
 pressing 'd' systematically destroys the feature if its fid is undefined,
 and I guess different behaviors may be wanted here.
 My propositions:
  * we add a {{{featurestatechanged}}} event type to {{{Layer.Vector}}}
  * we make {{{Feature.Vector.setState}}} trigger a
  * when 'd' is pressed we just do
 {{{feature.setState(OpenLayers.State.DELETE)}}}
  * the rest is business logic
 We should also modify {{{Control.ModifyFeature}}},
 {{{Control.DrawFeature}}}, {{{Control.Split}}}, {{{Handler.Polygon}}} to
 use {{{Feature.setState}}}.
 I hope it makes sense.
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
