[OpenLayers-Trac] [OpenLayers] #3042: Setting contentDisplayClass
on a FramedCloud popup has no effect
trac-20090302 at openlayers.org
Fri Feb 4 11:06:40 EST 2011
#3042: Setting contentDisplayClass on a FramedCloud popup has no effect
Reporter: slinkp | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.10 Release
Component: Popup.FramedCloud | Version: SVN
Keywords: | State:
I'm using SVN r10972 .
Test case (assuming you already have a map and a feature):
var map = ...;
var feature = ...;
var popup = new OpenLayers.Popup.FramedCloud(
null, feature.geometry.getBounds().getCenterLonLat(), null,
'test content',
{size: new OpenLayers.Size(1, 1), offset: new
OpenLayers.Pixel(0, 0)},
false, // closeBox.
null
popup.contentDisplayClass = 'overridePopupContent'; // has no
effect!
feature.popup = popup;
map.addPopup(popup);
The rendered popup still has a div with class="olFramedCloudPopupContent"
instead of "overridePopupContent".
Have not tested whether this affects other Popup classes.
Ticket URL: <http://trac.openlayers.org/ticket/3042>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
