[OpenLayers-Trac] Re: [OpenLayers] #3040: arcgis 10 WFS support
trac-20090302 at openlayers.org
Sat Feb 5 16:59:38 EST 2011
Reporter: travin | Owner:
Type: bug | Status: closed
Priority: minor | Milestone: 2.11 Release
Component: Format.GML | Version: 2.10
Resolution: wontfix | Keywords:
State: |
Changes (by tschaub):
* status: new => closed
* resolution: => wontfix
Comment:
Please use the {{{OpenLayers.Format.GML.v3}}} parser instead. Reopen the
ticket if your GML is not correctly parsed with that one (it assumes a
default dimension of 2). In fact, if you just leave out the
{{{readFormat}}} property in your WFS protocol config, you should get the
correct parser.
Ticket URL: <http://trac.openlayers.org/ticket/3040#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
