[OpenLayers-Trac] Re: [OpenLayers] #3052: pan while drawing
trac-20090302 at openlayers.org
Sun Feb 13 17:11:06 EST 2011
Reporter: erilem | Owner: tschaub
Type: feature | Status: new
Priority: major | Milestone: 2.11 Release
Component: Handler.Point | Version: 2.10
Keywords: | State: Needs More Work
Comment(by erilem):
Replying to [comment:9 jorix]:
> Replying to [comment:8 erilem]:
> >... Yes, you need to release the mouse to continue drawing the line in
non-freehand. Do you think that's a real issue?
> In my opinion, in this case, it should be added a point when mouseup
(expected by the end user). Is also the case that working with
stopDown:true, the behavior should be to add points when mouseup although
{{{this.lastDown.equals (evt.xy) === false}}}, this is what I think.
Thanks for the feedback jorix. See [attachment:patch-3052-A4.diff].
Ticket URL: <http://trac.openlayers.org/ticket/3052#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
