[OpenLayers-Trac] Re: [OpenLayers] #3058: Use correct maxResolution
for Web Mercator
trac-20090302 at openlayers.org
Mon Feb 14 05:52:05 EST 2011
#3058: Use correct maxResolution for Web Mercator
Reporter: ahocevar | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State: Needs More Work
Comment(by ahocevar):
Hm. This happens when running tests without clearing the cache first.
There are 3 different reasons for failing tests:
* Tests expecting {{{20037508.3392}}} as center lon ("edge of the world")
should expect {{{20037508.34}}}. This is because of the definition of the
map resolutions (see above). With this change, these tests pass.
* The test that expects {{{-12210356.6442}}} should now expect {{{100 *
map.getResolution() - 20037508.34}}}. Unfortunately the test still fails
after this change.
* The remaining failing tests fail because of values incorrect at a
magnitude of {{{1e-8}}}.
The interesting thing is: when setting
{{{OpenLayers.Util.DEFAULT_PRECISION = 0;}}}, all tests pass. So I suspect
that somewhere in the chain we should use {{{OpenLayers.Util.toFloat}}}
where we currently don't.
This needs further investigation.
Ticket URL: <http://trac.openlayers.org/ticket/3058#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
