[OpenLayers-Trac] Re: [OpenLayers] #3058: Use correct maxResolution
for Web Mercator
trac-20090302 at openlayers.org
Mon Feb 14 06:45:33 EST 2011
#3058: Use correct maxResolution for Web Mercator
Reporter: ahocevar | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State: Needs More Work
Comment(by bartvde):
Hi Andreas, I can confirm this, would it not make sense to change the test
script to use a precision of 13, and then change it back to the original
value when the tests are done? So that at least the test passes out of the
box.
Ticket URL: <http://trac.openlayers.org/ticket/3058#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
