[OpenLayers-Trac] [OpenLayers] #3100: make sure that container
positioning works at high resolutions
trac-20090302 at openlayers.org
Thu Feb 24 04:09:33 EST 2011
#3100: make sure that container positioning works at high resolutions
Reporter: ahocevar | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Map | Version: 2.10
Keywords: mobile | State:
After #3062, when e.g. playing with the osm.html example, the map gets
blank on zoom level 15 or higher. This is probably because the
layerContainerDiv position and/or dimension exceeds the valid range of
positions/dimensions supported by css.
Ticket URL: <http://trac.openlayers.org/ticket/3100>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
