[OpenLayers-Trac] [OpenLayers] #3114: setting layers and center in options causes moveTo to be called too often
OpenLayers trac-20090302 at openlayers.org
Fri Feb 25 06:14:56 EST 2011
 Reporter:  tschaub  |       Owner:
     Type:  bug      |      Status:  new
 Priority:  minor    |   Milestone:  2.11 Release
Component:  Map      |     Version:  2.10
 Keywords:           |       State:
 If you construct a map like this:
 var map = new OpenLayers.Map({
     // other options here
     layers: [myLayer],
     center: myCenter
 then the moveTo method will be called twice on your layer - the first time
 with bad bounds.  We can handle this case by deleting {{{map.center}}}
 before calling {{{addLayers}}}.
 The case that is '''not''' treated by this ticket is the following:
     center: myCenter
 map.addLayer(myCenter);
 I think it would make sense to delete {{{map.center}}} in this case as
 well, but there was a message on the mailing list about people relying on
 it being available after map construction (even though you can't call
 {{{addLayer}}} at this point).
Ticket URL: <http://trac.openlayers.org/ticket/3114>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
