[OpenLayers-Trac] Re: [OpenLayers] #3030: ArcGIS (AGS) Tile Cache Layer Contribution
OpenLayers trac-20090302 at openlayers.org
Fri Feb 25 09:57:25 EST 2011
 Reporter:  dmiddlecamp               |       Owner:  euzuro
     Type:  feature                   |      Status:  new
 Priority:  minor                     |   Milestone:  2.11 Release
Component:  Layer                     |     Version:  2.10
 Keywords:  ags, esri, layer, review  |       State:  Needs More Work
Comment(by dmiddlecamp):
 This was a situation where the layer is compensating for slightly atypical
 server results.  This override has been working very well across the
 configurations we've tested, but this layer will require a hook at the
 start of initGriddedTiles in some fashion, so we can adjust the extent
 appropriately.  I thought this was considerably safer than making changes
 to a fundamental base class.  Would an alternative version with some kind
 of pre-initGriddedTiles hook be a better solution?
Ticket URL: <http://trac.openlayers.org/ticket/3030#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
