[OpenLayers-Trac] Re: [OpenLayers] #2213: Yahoo reloads all tiles
on moveend
trac-20090302 at openlayers.org
Sun Feb 27 19:33:54 EST 2011
#2213: Yahoo reloads all tiles on moveend
Reporter: Specious | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Layer.Yahoo | Version: SVN
Keywords: | State: Review
Comment(by crschmidt):
This behavior is the result of the following:
1. When dragging the map, we use the 'dragging' flag. This flag causes
the EventPane layer to use the this.dragPanMapObject call to set the
center, rather than calling drawCenterAndZoom.
2. Because of pixel->lonlat rounding errors, most of the time when we
drop the map, we end up one pixel off. (This is probably in part because
of the projection change as well.) If you turn on sphericalMercator and
drag only horizontally, you'll see that the map doesn't redraw (if you
drag slowly): this is because the last mousemove was in the same place as
the mouseup, so the setCenter code doesn't get called.
Dropping this last moveTo has this as a side effect, but it also has other
negative side effects: basically, if you drag quickly on a slow computer,
your map will get left behind when you pick up your mouse, because we
don't move the map unless we're dragging. Something better might be to use
the dragPan handlers more often: that is, to use a looser definition of
when to use the dragPan handlers. (I'll be attaching a patch that does
this.) However, that would probably require more intimate understanding of
the underlying APIs than we'll ever get: given that the dragPan handlers
are usually hidden APIs, their behavior is not always well defined.
Instead, the Yahoo layer could specifically subclass moveTo and implement
it in this way; that would probably be the solution with the least
resistance (especially given the somewhat limited use that the Yahoo layer
currently has), and would fix the problem without potentially breaking
others.
Basically, on Yahoo!, it seems drawCenterAndZoom is really only meant to
be used rarely, not like the setCenter/moveTo in OpenLayers, or the
setCenter in most other APIs, which are 'cheap'. Instead, it does a full
redraw. (Googling for "moveByXy", I found someone who had expanded the
compressed Yahoo! code; it is very clear that panByXy is cheap, and
drawZoomAndCenter is 'expensive'.)
I'll attach two patches. The former might be good someday, for someone who
has time to test all our eventpane subclasses. The latter is the one I'd
recommend now, which would help actually fix this issue without much risk.
Tests continue to pass (though that doesn't mean much).
Ticket URL: <http://trac.openlayers.org/ticket/2213#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
