[OpenLayers-Trac] Re: [OpenLayers] #3126: Rotate the map using the
compass
trac-20090302 at openlayers.org
Mon Feb 28 04:18:29 EST 2011
#3126: Rotate the map using the compass
Reporter: sbrunner | Owner: sbrunner
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: mobile | State: Needs More Work
Changes (by sbrunner):
* keywords: => mobile
* state: => Needs More Work
Comment:
Well formated description:
Allows the map to rotate with the phone orientation.
What should be done:
* add get/setRotation on the Map.
* on the Layer change the methods getViewPortPxFromLonLat and
getLonLatFromViewPortPx using the rotation.
* get the missing tiles
* on single tile get a bigger tile
* on vector layer symbols and label should have the right orientation
* unit test
to test
* zoom by wheel
* zoom by dbl click
* drag pan should work
* pan controller should work
* mouse position
Ticket URL: <http://trac.openlayers.org/ticket/3126#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
