[OpenLayers-Trac] [OpenLayers] #3137: zoom out by single tap with
two fingers not working
trac-20090302 at openlayers.org
Mon Feb 28 05:10:25 EST 2011
#3137: zoom out by single tap with two fingers not working
Reporter: bbinet | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: mobile | State:
Currently, the pinch zoom control is activated after the click handler, so
it takes precedence over the click handler. Multitouch events are then
stopped by the pinch handler which will try to apply pinch zooming.
One solution could be to change order of activation of both controls and
create some logic in the click handler to detect if all touches remain at
the same location (given a tolerance). So we could detect if this is a
single tap with two fingers or if this is a pinch gesture to be propagated
to the pinch zoom control.
Ticket URL: <http://trac.openlayers.org/ticket/3137>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
