[OpenLayers-Trac] Re: [OpenLayers] #3030: ArcGIS (AGS) Tile Cache
Layer Contribution
trac-20090302 at openlayers.org
Mon Feb 28 07:50:50 EST 2011
#3030: ArcGIS (AGS) Tile Cache Layer Contribution
Reporter: dmiddlecamp | Owner: euzuro
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Layer | Version: 2.10
Keywords: ags, esri, layer, review | State: Needs More Work
Comment(by bartvde):
Hi David, I've added a new patch (work in progress though) that makes the
following changes:
* use getMaxExtent as proposed in ticket:3136
* change internal methods from APIMethod to Method
* use zeroPad from tschaub's sandbox instead
* inherit from !OpenLayers.Layer.XYZ instead
I still have a few questions for you:
* Why do you add 0 to the lod.scale in initialize?
* What is the main difference between your getURL function and the one
from tschaub in his sandbox? Any chance you can adapt his work instead of
rewriting? Or at least point out why you did it differently.
TIA for your patience.
Ticket URL: <http://trac.openlayers.org/ticket/3030#comment:9>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
