[OpenLayers-Trac] [OpenLayers] #2992: move OpenLayers.Util.extend
to Class.js
trac-20090302 at openlayers.org
Sat Jan 1 17:57:11 EST 2011
#2992: move OpenLayers.Util.extend to Class.js
Reporter: tschaub | Owner:
Type: feature | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
We have a number of circular dependencies in the library. The current
toposort method isn't flexible enough to handle these. In most places
where we have circular dependencies, the order that files are executed
doesn't matter. A more tolerant toposort method could resolve
dependencies even in circular cases - imposing an arbitrary order. Change
r10979 is an example of a simplified (and more tolerant) toposort method.
If we have a more tolerant toposort, then we can move dependency
declaration into the library source files. Doing this would remove the
need to force a specific order in a "first" section of a build
configuration.
The one place where we have a circular dependency that causes trouble is
with Class -> Util -> BaseTypes -> Class. The Class function only needs
OpenLayers.Util.extend. An arbitrary sort order will not guarantee that
Util is loaded before Class. One solution is to move the extend method
into the Class source file.
Ticket URL: <http://trac.openlayers.org/ticket/2992>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
