[OpenLayers-Trac] Re: [OpenLayers] #2992: move OpenLayers.Util.extend to Class.js
OpenLayers trac-20090302 at openlayers.org
Mon Jan 3 10:53:45 EST 2011
 Reporter:  tschaub  |       Owner:
     Type:  feature  |      Status:  new
 Priority:  minor    |   Milestone:  2.11 Release
Component:  general  |     Version:  2.10
 Keywords:           |       State:  Review
Description changed by tschaub:
Old description:
> We have a number of circular dependencies in the library.  The current
> toposort method isn't flexible enough to handle these.  In most places
> where we have circular dependencies, the order that files are executed
> doesn't matter.  A more tolerant toposort method could resolve
> dependencies even in circular cases - imposing an arbitrary order.
> Change r10979 is an example of a simplified (and more tolerant) toposort
> method.
> If we have a more tolerant toposort, then we can move dependency
> declaration into the library source files.  Doing this would remove the
> need to force a specific order in a "first" section of a build
> configuration.
> The one place where we have a circular dependency that causes trouble is
> with Class -> Util -> BaseTypes -> Class.  The Class function only needs
> OpenLayers.Util.extend.  An arbitrary sort order will not guarantee that
> Util is loaded before Class.  One solution is to move the extend method
> into the Class source file.
New description:
 dependencies even in circular cases - imposing an arbitrary order.  Change
 r10979 is an example of a simplified (and more tolerant) toposort method.
 configuration.
 Class is loaded before the BaseTypes.  One solution is to move the extend
 method into the Class source file.
Ticket URL: <http://trac.openlayers.org/ticket/2992#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
