[OpenLayers-Trac] Re: [OpenLayers] #2046: cannot combine draggable layer and selectable layer on one map
OpenLayers trac-20090302 at openlayers.org
Sat Jan 15 05:35:53 EST 2011
 Reporter:  yourcelf                                             |       Owner:  tschaub
     Type:  bug                                                  |      Status:  new
 Priority:  minor                                                |   Milestone:  2.11 Release
Component:  Control.SelectFeature                                |     Version:  2.7
 Keywords:  drag dragfeature selectfeature draggable selectable  |       State:
Comment(by bartvde):
 The problem here is that events cannot be handled on multiple vector
 layers. In order to support multiple vector layers, the SelectFeature
 Control uses a RootContainer, but since we are now dealing with both a
 SelectFeature and a DragFeature control this is not really an option.
 The real solution would be to integrate tschaub's FeatureAgent into
 OpenLayers, however this would be a significant effort of multiple days
 work at least.
 So as a workaround I came up with a temporary patch so that this use case
 can be supported in an application. I have tested the approach in FF3,
 Safari 5 and IE8. The workaround is a bit hacky at the moment, especially
 the part in Handler/Feature for which I need to find some more time to
 look into it, maybe then I can come up with a better solution.
 For now attaching the patch.
Ticket URL: <http://trac.openlayers.org/ticket/2046#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
