[OpenLayers-Trac] Re: [OpenLayers] #2936: Handler.Drag: Does not move until the cursor, and does not finish properly.
OpenLayers trac-20090302 at openlayers.org
Sun Jan 23 12:25:01 EST 2011
 Reporter:  jorix         |       Owner:  erilem
     Type:  bug           |      Status:  new
 Priority:  blocker       |   Milestone:  2.11 Release
Component:  Handler.Drag  |     Version:  2.10
 Keywords:                |       State:  Review
Comment(by jorix):
 Replying to [comment:5 erilem]:
 > [attachment:patch-2936-A0.diff] fixes the "jump on mouseup" issue. With
 the patch the jump occurs earlier, when the "delayed drag" timeout
 expires. So the patch does improve things in my opinion - better user
 experience.
 Perfect! I watched the patch: {{{this.lastMoveEvt = evt;}}} at the
 beginning of the method is very effective. (I put inside, so my code is
 more complicated :-()
 Question: Can be omitted to assign {{{this.delayedEvt = null;}}} at the
 end of  drag?
 > Small patches with restricted focuses are much easier to review.
 Yes, I know. I did not see the two bugs could be independent. I worried
 about leaving active {{{setTimeout}}} so I looked at the completions of
 the drag.
 > Tell me if you think some of your tests could be added to my patch.
 Thanks for reporting the issue and the patch.
 The tests are designed to testing thoroughly proper completion of drag. In
 a new ticket? [[BR]]
 Only a very small affect the behavior of your patch, but to add them
 should dismantle the structure of the tests. I prefer not to touch the
Ticket URL: <http://trac.openlayers.org/ticket/2936#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
