[OpenLayers-Trac] Re: [OpenLayers] #2936: Handler.Drag: Does not
move until the cursor, and does not finish properly.
trac-20090302 at openlayers.org
Sun Jan 23 16:58:02 EST 2011
#2936: Handler.Drag: Does not move until the cursor, and does not finish properly.
Reporter: jorix | Owner: erilem
Type: bug | Status: new
Priority: blocker | Milestone: 2.11 Release
Component: Handler.Drag | Version: 2.10
Keywords: | State: Review
Comment(by erilem):
[attachment:patch-2936-A1.diff] comes with tests, and addresses the case
where a new mousedown occurs before the timer triggers.
@jorix,
* I don't see any problem with not setting {{{lastMoveEvt}}} to
{{{null}}} after drag. Could you please provide a test case if you see
one?
* With this patch leaving an active timer shouldn't cause any issue,
because of the {{{if(this.dragging)}}} guard. Again, please provide a test
case if you see an issue.
Ticket URL: <http://trac.openlayers.org/ticket/2936#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
