[OpenLayers-Trac] Re: [OpenLayers] #2522: Format.CQL for seralizing
and deserializing filters
trac-20090302 at openlayers.org
Fri Jan 28 17:29:10 EST 2011
#2522: Format.CQL for seralizing and deserializing filters
Reporter: tschaub | Owner: tschaub
Type: feature | Status: assigned
Priority: minor | Milestone: 2.11 Release
Component: Format | Version: 2.8
Keywords: | State: Review
Comment(by tschaub):
This will make a really great addition. In reviewing, I've caught a few
things and added tests. There is still one failing test. Here's what
I've done so far:
* removed trailing commas to get it to load in IE
* added semicolons where appropriate (improves things with our limited
compressor)
* updated example to allow users to change CQL and see results
* added CQL.js format to OpenLayers.js loader
* added docs
* made it so comparison filters are written with quoted strings only
(numbers were quoted as well)
* added write support for WITHIN, INTERSECTS, CONTAINS
* replaced use of bracket notation with {{{charAt}}} for strings (the
former doesn't work in IE and was causing infinite recursion)
* made infinite recursion less likely in the balanced parentheses matcher
for geometries
* made it possible to use spatial filters in a logical filter - this
required adding SPATIAL before PROPERTY to the list of follows for LOGICAL
(tests pass, but this needs confirmation as the right thing to do)
* made it so spatial filters store geometries instead of features
Ticket URL: <http://trac.openlayers.org/ticket/2522#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
