[OpenLayers-Trac] [OpenLayers] #3399: Control.DragFeature:
Sometimes not detected "mouseout" dragging points
trac-20090302 at openlayers.org
Sat Jul 2 04:36:21 EDT 2011
#3399: Control.DragFeature: Sometimes not detected "mouseout" dragging points
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Drag | Version: 2.10
Keywords: | State:
Sometimes not detected {{{mouseout}}}, EG dragging vertices using
{{{Control.ModifyFeature}}}.
Try moving a vertex out of the map (to the top o to !PanZoom) using
[http://openlayers.org/dev/examples/wfs-snap-split.html wfs-snap-
split.html]. {{{mouseout}}} fails too often in this example.
I have been able to verify that when leaving the map, sometimes the
{{{mouseout}}} event does not occurs.
In tests I've done browsers Safari5 Chome12 FF3.6 fail, but IE works
perfectly (from IE6 to IE9).[[BR]]
Usually the failures are sporadic, but if you use a {{{styleMap}}} with
{{{"Point": {graphicName: "square"}}}} then the failures are frequent (I
tested it by changing {{{styleMap}}} in "examples/modify-feature.html", in
this case Chrome & Safari fail more often than FF).
The failures are produced using any of the three renderers: {{{SVG}}}
{{{SVG2}}} and {{{Canvas}}}. Using {{{Canvas}}} I could not see the effect
of square dot as a result of #3396
'''NOTE''': This bug is more important if patch #3363 is applied.
Ticket URL: <http://trac.openlayers.org/ticket/3399>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
