[OpenLayers-Trac] Re: [OpenLayers] #3399: Control.DragFeature: Sometimes not detected "mouseout" dragging points
OpenLayers trac-20090302 at openlayers.org
Sun Jul 3 06:47:04 EDT 2011
 Reporter:  jorix         |       Owner:
     Type:  bug           |      Status:  new
 Priority:  minor         |   Milestone:  2.11 Release
Component:  Handler.Drag  |     Version:  2.10
 Keywords:                |       State:  Awaiting User Feedback
Comment(by jorix):
 Replying to [comment:6 ahocevar]:
 > In this case it would be extremely helpful if you could provide your
 code with added logging, and a dump of a log that shows where things
 failed.
 Of course!
 [attachment:log_the_bug_unfiltered-3399.patch
 log_the_bug_unfiltered-3399.patch] allows for easy annotations of missing
 events in browsers.
 About logs:
  * "mouseout" and "safeOut" logs use {{{OpenLayers.Util.mouseLeft}}} to
 detect "Out"
  * "safeMove" use {{{Drag::mousemoveLeft}}} to detect "Out"
 The patch includes the adaptation of two examples:
  * "wfs-snap-split.html": Added the firebug.
  * "modify-feature.html": Added {{{styleMap}}} for square dots, this
 causes the failures are very frequent. Removed {{{Console.Log}}} on line
 44.
 Two examples of logs:
 1. Leaving the map by the top:
 safeMove | Out: false x=97,y=87 | polygon id=""
 safeMove | Out: false x=97,y=77 | svg
 id="OpenLayers.Layer.Vector_48_svgRoot"
 mouseout | Out: false x=96,y=73 | polygon id=""
 safeOut | Out: false x=96,y=73 | polygon id=""
 safeMove | Out: false x=96,y=73 | polygon id=""
 safeMove | Out: true x=96,y=68 | DIV id="map"
 safeOut | Out: true x=95,y=66 | P id="shortdesc"
 safeMove | Out: true x=95,y=66 | P id="shortdesc"
 safeMove | Out: true x=95,y=64 | P id="shortdesc"
 safeMove | Out: true x=95,y=63 | P id="shortdesc"
 2. Moving towards !PanZoom and moving to another button
 safeOut | Out: false x=78,y=163 | polygon id=""
 safeMove | Out: false x=78,y=163 | polygon id=""
 safeMove | Out: false x=73,y=163 | svg
 mouseout | Out: false x=69,y=163 | polygon id=""
 safeOut | Out: false x=69,y=163 | polygon id=""
 safeMove | Out: false x=69,y=163 | polygon id=""
 safeMove | Out: false x=63,y=163 | svg
 safeMove | Out: false x=58,y=163 | svg
 mouseout | Out: false x=56,y=164 | polygon id=""
 safeOut | Out: false x=56,y=164 | polygon id=""
 safeMove | Out: false x=56,y=164 | polygon id=""
 safeMove | Out: true x=52,y=165 | IMG
 id="OpenLayers.Control.PanZoom_2_zoomworld_innerImage"
 safeMove | Out: true x=50,y=166 | IMG
 ... the same, 13 "safeMove" logs
 safeMove | Out: true x=40,y=171 | IMG
 safeOut | Out: true x=41,y=172 | IMG
 id="OpenLayers.Control.PanZoom_2_zoomout_innerImage"
 safeMove | Out: true x=41,y=172 | IMG
 These logs are obtained by using the example "wfs-snap-split.html" and
 using Chrome. Using Safari or FF quickly observed similar results, with
 either "wfs-snap-split.html" or "modify-feature.html" examples. [[BR]]
 For "modify-feature.html" with FF failures occur only sporadically, see
 ticket description.
Ticket URL: <http://trac.openlayers.org/ticket/3399#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
