[OpenLayers-Trac] Re: [OpenLayers] #3399: Control.DragFeature:
Sometimes not detected "mouseout" dragging points
trac-20090302 at openlayers.org
Sun Jul 3 11:26:34 EDT 2011
#3399: Control.DragFeature: Sometimes not detected "mouseout" dragging points
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Drag | Version: 2.10
Keywords: | State: Awaiting User Feedback
Comment(by ahocevar):
I was finally able to drag this down to OpenLayers.Util.mouseLeft failing,
and here's the evidence. Apply [attachment:dragfeature-mouseleft.patch] to
current trunk, fire up the modify-feature.html example, draw a polygon,
modify it, and drag its vertices outside the map. You'll see something
like the following in log:
true
documentevents
true
The first true-documentevent sequence is from a working drag that
continues outside the map. The second true is from a drag that stops at
the map border.
Further explanation: Both log outputs are generated in
Handler.Drag::mouseout. The logged true is the handler's started property.
documentevents is logged as soon as document dragging is activated. The
only step in between is the check that invovles OpenLayers.Util.mouseLeft
- which has to return true so the documentevents log point is reached.
Ticket URL: <http://trac.openlayers.org/ticket/3399#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
