[OpenLayers-Trac] Re: [OpenLayers] #3399: Control.DragFeature:
Sometimes not detected "mouseout" dragging points
trac-20090302 at openlayers.org
Sun Jul 3 17:38:36 EDT 2011
#3399: Control.DragFeature: Sometimes not detected "mouseout" dragging points
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: Handler.Drag | Version: 2.10
Keywords: | State: Needs More Work
Comment(by jorix):
Replying to [comment:14 ahocevar]:
> @jorix: while [attachment:openlayers-3399.1.patch] also adds some
overhead, it adds less overhead than your patch. Can you please confirm
that it also solves the issue?
This does not work, it requires more adjustments. Try using
{{{documentDrag = false}}}, oops! can not move the vertices. [[BR]]
This is because in this case should be used {{{Drag::mousemoveLeft}}}
instead of {{{Util.mouseLeft}}}, due to the differences between
{{{"mousemove"}}} event object and {{{"mouseout"}}} event object.
NOTE: I tried adding in "3399.1.patch" a timer and unregister "mouseout"
(is redundant with {{{_docSafeOut}}}), this improves performance a bit.
But it is difficult to evaluate objectively, since in many cases the
execution of a method takes less than one millisecond.
Ticket URL: <http://trac.openlayers.org/ticket/3399#comment:15>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
