[OpenLayers-Trac] Re: [OpenLayers] #3359: svg2: rendering problem in firefox
OpenLayers trac-20090302 at openlayers.org
Sat Jul 9 11:17:48 EDT 2011
 Reporter:  arno         |       Owner:  ahocevar
     Type:  feature      |      Status:  new
 Priority:  minor        |   Milestone:  2.12 Release
Component:  Renderer.NG  |     Version:  2.10
 Keywords:               |       State:  Review
Changes (by ahocevar):
  * state:  => Review
Comment:
 Thanks @arno for the test case. I simplified it a bit and included it as
 manual test case in [attachment:openlayers-3359.patch].
 The solution was indeed to reduce the range of CSS coordinates used, by
 changing the renderer's extent from the map's maxExtent to the current map
 extent scaled by 3.
 The manual test now passes in FF3, FF4, FF5 and Safari5. Unit tests still
 pass in Safari5. Thanks for any review.
Ticket URL: <http://trac.openlayers.org/ticket/3359#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
